Oops fitting on the (old) Onex tank
Re: Oops fitting on the (old) Onex tank
Postby WesRagle » Thu Sep 12, 2019 1:46 pm
inventor wrote:Yes, I have an old unused tank. Wish I knew the real name of the OOPs fittings.
I wish I knew the real name of whoever posted this message :-)
It's easy to go to your user control panel > user profile > edit signature and automatically sign your name to each post. That way we wouldn't have to call you "guy", or worse, some make believe name.
Reference https://www.sonexaircraft.com/eshop/cart.php?target=search&substring=oops+fittings
Good Luck,
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby GordonTurner » Thu Sep 12, 2019 1:58 pm
Postby GordonTurner » Thu Sep 12, 2019 6:28 pm
I didnt use the oops fittings, they seemed a little flimsy for my taste. The problem you will need to address is the thickness of the tank walls will probably require a longer “bulkhead” portion than the pictured item. I found a source for beefy stainless steel bulkheads fittings, which were pricey....but we are talking about a gas tank in your lap...
Postby inventor » Thu Sep 12, 2019 7:43 pm
Yes, not a happy place to have a gas leak in the air.
Onex 150
inventor
Postby Bryan Cotton » Thu Sep 12, 2019 8:04 pm
That looks cool. Less junctions to worry about. Except how do you ensure the nut doesn't come loose in the tank? How do you tighten it?
Postby inventor » Thu Sep 12, 2019 8:24 pm
I need to get one of my grandkids with skinny arms to reach in there and put the nut on.
Onex 150
inventor
