Heat for a Onex
Heat for a Onex
Postby dfcpac » Sun Sep 17, 2017 9:29 am
Does anyone make a cabin heat system for the Onex with the Revmaster
Engine? If so where can I get it
Thank you
Dan Carley
N127nx
dfcpac
Re: Heat for a Onex
Postby Mike53 » Sun Sep 17, 2017 5:07 pm
dfcpac wrote:Does anyone make a cabin heat system for the Onex with the Revmaster
Thank you
Dan Carley
N127nx
The easiest solution is a heat muff over one of the exhaust pipes and then channel the air into the cabin.Here is mine.As you can see the hose goes to a box on the firewall where you can either dump the heat or direct it into the cabin.If you can't make your own muff I'm sure someone here will pipe in where you might get one or how they made there own.The gent I ordered mine from no longer does them.
http://www.onexmike.org/uploads/8/4/4/2 ... 2_orig.jpg
Antoine de Saint-Exupery
Mike53
Re: Heat for a Onex
Postby dfcpac » Sun Sep 17, 2017 5:40 pm
Thanks mike
I have no way of making one. Maybe some one can direct me where to
Purchase one and some kind of valve
For the cabin
Danny
dfcpac
Re: Heat for a Onex
Postby tom0nex74 » Mon Sep 18, 2017 1:56 pm
Air ward has a heater kit for the 0nex. I have one in 0nex 74. It works well and is relatively easy to install.
Tom Ryan......0nex 74
tom0nex74
Re: Heat for a Onex
Postby vhhomer » Sun Oct 01, 2017 7:14 am
Do you have a web address for Air Ward. I can't seem to find them.
vhhomer
Re: Heat for a Onex
Postby MichaelFarley56 » Sun Oct 01, 2017 8:53 am
Try www.airward.com and you’ll see a bunch of options on the left side of your screen.
Waiex #0056 - N569KM
Jabiru 3300A #1706
Re: Heat for a Onex
Postby XenosN42 » Tue Jan 02, 2018 1:12 pm
The http://www.airward.com site has the worst web page layout I've ever seen. Don't believe me - just take a quick look.
-- Michael
OneX N169XE
XenosN42
