by 13brv3 » Wed Oct 21, 2015 12:46 pm
I suspect you're right Mike. The difference in empty and max gross weight allows for a pretty big pilot, and I should fall well under that if I don't make the plane too heavy adding other stuff (turbo, diff brakes, etc).
FWIW, I asked Sonex via email after starting this thread, and they said the longer wingtips were necessary to remain sport pilot compliant. I'm assuming that means at max gross weight though.
Fortunately, the wingtips are something I can decide on later, or not. I can easily imagine using screws to attach them, and being able to try both sizes. My more immediate decision is turbo or non-turbo, since I need to get the engine and prop ordered.
Cheers,
Rusty
Rusty
Onex- Rotax 912 (130 hours and counting)
Fixed wing, gyroplane, A&P
