Onex seat cushion
Onex seat cushion
Postby Mike53 » Sat Mar 21, 2015 6:39 pm
Hello Onex builders.
For those that have bought the Onex seat cushion from Sonex can you give me the dimensions .length and thickness of bottom cushion and same for back.
$425 is a bit dear and once I pay the exchange it would work out to over $500 so I will get it made locally.
Mike
Mike
Antoine de Saint-Exupery
Mike53
Re: Onex seat cushion
Postby XenosN42 » Sun Mar 22, 2015 10:33 am
Hi Mike,
The Sonex supplied OneX seat cushion dimensions are:
Back:
50cm wide x 45 cm high x 4 cm thick
Seat:
50cm wide x 48 cm long (measured from front to back) x 4 cm thick
There is a 10 cm wide x 6 cm long cutout centered in the middle of the seat front for stick clearance.
Have fun building!
N42XE - XENOS flying 3-1/2 years
N169XE - OneX - less than 6 weeks from first flight!
-- Michael
OneX N169XE
XenosN42
Postby Mike53 » Sun Mar 22, 2015 4:32 pm
Thanks Michael.
Mike
Mike53
Postby Onex107 » Mon Apr 06, 2015 9:53 am
Something you might consider is a wheel chair seat cushion. They are made for long time sitting and run about $40 U.S. They don't have the cutout for the stick but they are about the right size.
OneX 107
N2107X
Onex107
Postby Mike53 » Mon Apr 06, 2015 5:34 pm
Probably a great idea but I have already purchased my foam .I got this site from this forum but just to put it out there again,here is where I purchased the foam from.
Same stuff as condor but a lot cheaper.Check out the discount section .
http://www.sunmatecushions.com/
Mike
Mike53
Return to Onex
