Hey Guys,
Rofomoto wrote:Nice job Wes!
Thanks Billy! No comment on the T-Shirt :-)
XenosN42 wrote:The empty weight of my OneX is 627 pounds, which includes the weight of the vinyl wrap covering. So you are a bit on the heavy side.
Hi Michael. Yea, you really need to think about it before messing around with the plans very much. The main things that cost me were using a pre-assembled VW and the aftermarket landing gear, and now I'm a porkster.
The Home Built Help videos that came with my Onex kit showed Jan Eggenfellner helping the "Home Built Help" guy with a Onex build. During the latter portion of the build it could be seen that they had hung a Viking engine on the nose. A Onex with that engine showed up years after the video was made, partially assembled, on Barnstormers. In the pictures you could see that the prop was way close to the ground. Also, back in the early days of the Onex, Jan was showing a Viking cowled up on a Onex (tri-gear none the less) on his web site. Again, I'll bet it was the same plane. I'll lay odds it never flew with that engine. Based on my experience it would be a real chore to get the CG in line with a Viking. Were talking a lot of ballast or the battery strapped to the tail post :-) Then, with a tri-gear, the first bump you hit you could buy a new prop. Just my 2 cents, and worth every penny.
Wes
