Skippydiesel wrote:I have asked this before - yet to get an answer.
Is there some reason why the fuel point can not be moved in front of the firewall ie forward into the the rear of engine bay. A suitably designed flap (size & hinge point), could open to prevent splash onto polycarbonate and any overfill, would drain out of the bottom of the engine bay OR be caught by a well/bund arrangement, that could drain through a pipe onto the ground.
I sure hope the new high wing comes up with a better, fueling, arrangement.
sonex892. wrote:Skippydiesel wrote:I have asked this before - yet to get an answer.
It appears the high wing is using the same through the lexan fill point. I get nervous enough filling an A model tank adjacent to the lexan.
Skip this is off topic. Do you have a schematic of your fuel system including venting you would be willing to share? I'm at the decision point on the Sonerai I'm building. I has 2 x 35 litre wing tanks and a 24 litre header.
