EdW wrote:OK, with all the AeroInjector carb bashing aside (this is, after all, NOT an engine problem, per se) after reading comments and doing a bit of research, it looks to me that we have, in the VW engine, a reasonable robust basic engine. Catastrophic failures can happen to any engine, and they have, but to a small sample. I saw one report regarding a Force One hub, and one report about an alternator (magnet?) coming loose, as well as a couple of complaints about the ignition system. Of course, there are the nicrosil (sp?) cylinders, but that problem has supposedly been remedied.
Over all, these complaints are minor in both scope and occurrence. The majority of problems are well known, and fixes available. Due-diligence and an analytical approach. The engine itself seems to be a stout little pony, with us, the builders and maintainers wringing our hands because some curable accessory problem raised its' ugly head.
Yes, these glitches are nerve-wracking. Yes, they sometimes teach us new words. And yes, unfortunately, sometimes we get hurt. But remember, the word "EXPERIMENTAL" is written on our airplanes for a reason.
After reading what I could find regarding the VW engine I am convinced we have a nice little (relatively) inexpensive powerplant that has minor vices that for the most part are fixable.I guess I'll stick to my decision to fly behind a 'bug' motor.
Ed
That was a good response. Hopefully true as I was starting to second guess if I should build a Sonex or not. I drive behind a bug motor today, and wish this was the engine I was using! (2.0 water cooled direct injected Turbo, 280hp/325tq)....
We live and learn.
then die and forget it all.
ScottM-Sonex1629 wrote:I’m not trying to say shut up and hide known problems....
EdW wrote:But all I asked for was factual data, possibly from those of you who have the best (first hand) recollections. I feel bad that my inquiry lit up the board.
Now that the situation of factual information is out in the open, is there any progress in getting a FACTUAL data base started here? It would be beneficial to all, builders and prospective builders alike. If just one mishap is averted by what someone wrote/read here the 'teething pains' will be well worth it.
sonex1374 wrote:The burps are not a new thing, nor are the reasons why a mystery. The cause and solution is simple. Burps are caused by fuel vapor bubbles traveling through the AeroCarb and into the engine. When a vapor bubble hits the intake, the mixture goes lean and the engine stumbles. This is the "burp".
Folks, the bottom line is this. The burps are something that we understand, and the solutions are well known. Do your fuel system properly using the accumulated knowledge, and you'll be just fine.
Jeff
daleandee wrote:It ain't as bad as it may seem. I trust no one gets offended when the conversation gets to the adult stage. In truth a lot was learned here. I've had several off line conversations during this thread and many agree that some things need to be said although sometimes it's difficult to go through the process ... what you note about divorce lawyers is true.
