sonex1374 wrote:Folks, the bottom line is this. The burps are something that we understand, and the solutions are well known. Do your fuel system properly using the accumulated knowledge, and you'll be just fine.
Jeff
daleandee wrote:mcjon77 wrote:That is what I remember too. IIRC, the "burping" issue wasn't limited to Aerovees. Jabirus that were using the Aerocarb instead of the standard bing carb also had that issue ...
You are quite correct. The problem with burps isn't the engine it's the Aerocarb. I was excoriated on this list for giving my personal opinion on the Aerocarb so I dare not repeat it. But I believe this "burping" issue is serious enough that every new builder that intends to use an Aerocarb should be made aware of it.
Here is a video example of the burps: https://www.youtube.com/watch?v=S6GD5s7osHE
If my airplane did that on the take-off roll it would be back in the hangar. My airplane should run at least as good as the truck I drove to the airport.
Dale Williams
N319WF @ 6J2
Myunn - "daughter of Cleanex"
120 HP - 3.0 Corvair
Tail Wheel - Center Stick
171.9 hours / Status - Flying
Latest video: https://www.youtube.com/watch?v=1VP7UYEqQ-g
SonexFactoryTech wrote:daleandee wrote:mcjon77 wrote:That is what I remember too. IIRC, the "burping" issue wasn't limited to Aerovees. Jabirus that were using the Aerocarb instead of the standard bing carb also had that issue ...
Dale Williams
N319WF @ 6J2
The burping is vapor/air in the fuel passing through the AeroCarb/AeroInjector, which introduces a momentary lean condition in a cylinder. Saying the burp is caused by an AeroCarb/AeroInjctor is like saying a float-bowl carburetor causes water to accumulate in the float bowl, in turn causing an engine stoppage. Water in the fuel is what causes water in the float bowl and an engine stoppage.
There is no magic to an AeroInjector/AeroCarb. All it does it accept whatever the fuel system delivers in the way of fuel (or air, or water, or debris) and mix it with the air the engine sucks in with each intake stroke (and that depends on valve settings, valve timing, ring condition, air filter, etc.).
So how do you eliminate burps? First, not everyone with an AeroInjector/AeroCarb has them. But if you do have them you examine the fuel system to make sure air/vapor cannot pass through your fuel lines or get trapped in your fuel and you take steps to keep your fuel cool to prevent it from turning to vapor before it reaches the AeroInjector. Low octane fuel (mogas) goes to vapor at a lower temperature than 100LL.
I agree with Dale on this comment:
"If my airplane did that on the take-off roll it would be back in the hangar. My airplane should run at least as good as the truck I drove to the airport."
Unfortunately, not every pilot feels the same and not every builder takes care in their workmanship or maintenance. "Maybe if I just fly it enough it will fix itself." "I was told they just do that." An amazing number of first flights are conducted with the builder not having taken any steps to tune their engine. A growing number of airplanes are changing hands and their new owners are fully unfamiliar with what they purchased and where to begin to sort out the issues the airframe or engine present them. The problem is further compounded by airplanes that have systems modified by the original builder (or the second, or third, or fourth owner), leaving the new owner with a system they assume is correct but is, in fact, a prototype.
Kerry Fores
Sonex Tech Support Manager
Builder s/n 009, N912SX, "Metal Illness"
2006 AirVenture Plans Built Champion
500 hours flying on an AeroCarb
22,000+ hours providing Sonex/AeroVee/AeroCarb/AeroInjector Support
Gordon wrote:RE: Insulating Fuel Lines
I have just one short comment in regard to insulating anything with "plumbers pipe insulation". The stuff I tested was quite flammable and also gave off toxic vapors when ignited. A good reason you don't see it on a certified airplane.
Use the proper "fire sleeve" material..........there is a reason it costs more.
Gordon..........Onex.....Hummel 2400
kmacht wrote:A real solution would be to redesign the aerocarb so it isn't susceptible to air bubbles in the first place.
SonexN76ET wrote:I would like to second Jeff’s recommendations on eliminating the burps. I have done as Jeff recommends and have not had any burps even in the afternoon summer in Florida.
I would also like to defend my friend Scott. We all know there are a small group of people on this forum who love to beat up the Aerovee and Sonex. I do not believe that Scott was addressing legitimate issues people have from time to time but was rather addressing those few who are very vocal and never have anything good to say. These few people often dominate this forum and make it sound like the sky is falling.
As for me, I am going to go finish my annual condition inspection and go flying...
Jake
Users browsing this forum: Bing [Bot] and 24 guests
