Page 2 of 14
Re: A couple of questions
Thu May 09, 2019 11:27 pm
by WesRagle
Thanks Brian,
Hey Gordon, are you out there?? Do you know where the "tool" is?
I'll send a private message as well.
P.S.
Nothing like hanging the noisy part on the front to get the blood pumping :-)
Temporary lexan firewall installed. Hope to make all of my mistakes on the lexan then transfer only the good holes to stainless.
We'll see.
![Image](https://i.postimg.cc/0N4C00Pq/P1020306.jpg)
Fri May 10, 2019 9:15 am
by DCASonex
The Oops fitting tools are back home and ready to go out again. Cost is that of shipping via Priority Mail (within the US) which is now about $7.20. to be included in box when returned. Gordon and Rick had some problems with the tools that seems to have been due to much too fine a grade of sanding mesh having been packed with the tools. That has been replaced with courser stuff. PM me your address to get them shipped out. Include your direct e-mail address and I will send a .pdf file with suggested instructions. (a copy is also packed with the tools)
Fri May 10, 2019 9:23 am
by WesRagle
Hi David,
PM sent.
Thanks
Mon May 13, 2019 9:59 pm
by WesRagle
Hi Guys,
Thanks David, got the tools today. Oops fittings should arrive Wednesday (I think).
While waiting on the bits to come together to install the oops fittings I have been working on the nose of the airplane. While fitting the cowl I made about 10 million sharpie marks. Per usual, I used alcohol to remove the marks. I got some alcohol on the inside of the cowl and it instantly got sticky. I didn't expect such a mild solvent to have that effect.
Being what it is, the cowl needs to be a bit more resistant to solvents, oil, fuel, etc.
Questions:
1) I have West Systems epoxy on hand. Is West Systems compatible with whatever the cowl is made of? That is, can I seal the inside of the cowl with a coat of West Systems epoxy?
2) What did you guys use to trim the Lexan windshield?
![Image](https://i.postimg.cc/fyx5P1P6/P1020316.jpg)
Thanks for Your Time.
Mon May 13, 2019 11:22 pm
by wlarson861
I just fitted a new cowl from Sonex for a legacy Sonex. I used West system epoxy to both add cloth and Micro balloon filler. It didn't seem to be an issue.
Tue May 14, 2019 3:51 am
by dirkverdonck
Hi Wes,
After nearly a year without doing anything to the inside of the cowling, all is fine. The resistance to fuel and oil is apparently ok.
I used angled grinders to cut the windshield, see pics. One equipped with a very fine cutting disk, the other with a flap disk to grind afterwards.
Tue May 14, 2019 5:54 am
by WaiexN143NM
hi wes,
we used the contego latex fire barrier avbl from aircraft spruce to coat the inside of the cowl. about $30 a quart. a foam brush and 30 min and it looks great.
WaiexN143NM
Tue May 14, 2019 7:48 am
We used a bandsaw to trim both the windshield and canopy. We finished with a belt sander then a sanding block. Final pass was just sandpaper held by hand to knock off the corners.
Tue May 14, 2019 8:23 am
by DCASonex
Best thing i have found to trim windshield, canopy and cowl parts is one of the oscillating multi-tools with a fine tooth half moon blade. Trick is to first drag a shallow cut line, then deepen it with successive passes rather than cutting through in one go. This avoid shaking the material being cut since cutting action occurs along the surface, not at right angles. If cutting off a large piece, be sure to support the cut off part so that the last remaining bit is not stressed by weight of cut off part.
When working with Lexan, it is very important to insure the cutting tools, including drill bits, taps, and saw blades, are not contaminated with any oils or other residue, or cracks will develop. With acrylic, like the canopy, avoid all scratches, and rough edges. and try \to install so that there is little or no residual stress in the material from pushing it into shape. (Unfortunately, the latter was almost impossible on the old A series Sonex as the canopy was curved where it needed to join the straight sides of the fuselage.)
Tue May 14, 2019 8:34 am
by DCASonex
Michael,
Thanks for the note on the Contego fire barrier paint. was not ware of its existence, looks like good idea. Will have to see if can get my 7 year old cowl clean enough to try that.
