ONX-W04
Discussion for Onex builders on specific plans page experience. These posts are limited to technical suggestions such as assembly order, challenges, or techniques related to specific plans pages.
ONX-W04
Postby A10snoopy » Wed Jul 23, 2014 9:56 pm
I am working on my aileron counterweights. Does anyone have any tips or suggestions on how to cut the lead counterweight? Paul Onex 76
A10snoopy
Re: ONX-W04
Postby Mike53 » Wed Jul 23, 2014 10:06 pm
Paul ,I cut mine on my table saw.You have to go slowly but I guarantee it will work great.I used an 80 tooth blade simply because that's all I have. For drilling the holes scroll down the page to my comments and pic's http://www.onexmike.org/ailerons-and-flaps.html
Do not try to drill all the way through from one side .
Cheers
Antoine de Saint-Exupery
Mike53
Re: ONX-W04
Postby onex28 » Thu Jul 24, 2014 8:03 am
I cut mine on a band saw. Lead tends to fill saw teeth and drill bits so go slow and back out and clear the lead as needed. The next time I saw lead I'll freeze it overnight to see if it cuts better.
David
onex28
onex28
Re: ONX-W04
Postby Darick » Sat Jul 26, 2014 2:10 pm
Try my tips and tricks on my a Expercraft builders log. Easiest way to find my log is to search Light Earth Aviation. A judicious use of tool Lub/coolant worked for me.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Re: ONX-W04
Postby Onex0119 » Mon Jul 28, 2014 5:21 pm
I made a clay mold, melted the lead in an iron bowl on a propane camp stove in the back yard. Came out fine.
Onex0119
Return to Onex Plans
