XenosB Errata
Discussion for Xenos builders on specific plans page experience. These posts are limited to technical suggestions such as assembly order, challenges, or techniques related to specific plans pages.
XenosB Errata
Postby drPete » Sat Sep 16, 2017 9:15 am
XenosB Drawings, Errata List as of 16 Sept 2017
    Drawing, Error, Identified by
    XNB-C01 (G) Call is for AN3 fasteners, dwg XNB-T10-3 indicates 1/4" holes. PDailey
    XNB-C01 (K) No sinterd bronze SF-type bearings specified. QB has SNB-F16-06L&R drilled larger than 1/4" for called AN4 bolt. PDailey
    XNB-C01 (L) Call for AN4-30 bolt is too long. PDailey
    XNB-C03 SNB-C04-03 single grip tube hole diameter not specified. PDailey
    XNB-C04 XNB-C04-04 Spoiler Cable Adjuster Plate, material thickness calls for 0.090" 6061-T6. Should call for 0.190". PDailey
    XNB-C04 SNB-C04-02 'A' frame hole size for trim spring not specified. PDailey
    XNB-C05-03 Sonex identified
    XNB-C06 Drawing Number incorrectly identified as XNS-C05 PDailey
    XNB-C06-10 Spelling: "Maek" PDailey Spelling: "Thich" PDailey
    XNB-D01 Spelling: "Safty Canopy Pin Detail" PDailey
    XNB-F03 Sonex identified
    XNB-F08 XNB-F08-02 incorrectly calls for hinge 2 on bottom of -02 PDailey
    XNB-F08 Sonex identified
    XNB-F09 Sonex identified
    XNB-F10 Sonex identified
    XNB-F12 Sonex identified
    XNB-F16 Sonex identified
    XNB-F19 Sonex identified
    XNB-F20 Sonex identified
    XNB-21 Detail B AN3-6 should be 6A PDailey
    XNB-F22-14 Cable fairing length should be 1" PDailey
    XNB-F25-05R Spelling: "cable required to retain cable onl" PDailey
    XNB-G01 Detail of Tank Assembly 45 elbow NPT to flare should be MS20822 not AN915 PDailey
    XNB-L01 (B) AN310 missing diameter, should be AN310-12 PDailey
    XNB-L03 View B-B Tricycle landing gear mount artifact PDailey
    XNB-L04 Sonex identified
    XNB-L05 Sonex identified
    XNB-P13 Sonex identified
    XNB-P14-01 spelling: "engin" PDailey
    XNB-W21 Sonex identified
    XNB-W25 Sonex identified
    XNB-W37 Sonex identified
Xenos-B s/n XNB0010
Return to Xenos Plans
