Sonex B F11 Tri gear installation
Postby SP1 » Fri Dec 11, 2020 12:35 am
Hello,
I’m trying to understand the best order to install the L04-02 welded main landing gear part. On F11, it mentions to do F5 first, which seems to pull fromL04. The drawing tree doesn’t show that dependence, however.
I want to avoid having to adjust L04-02 to sit flush against the floor and side. Is a good order to slip the aft tunnel web assembly (F16-03) into the fuselage, clamp L04-02 against F16-03,then position F16-11 vertical angle, then drill?
How did others do this? The dependencies seem somewhat circular...
SP1
Return to Sonex Plans
