AeroConversions pitch trim installation with matched hole pa
Postby Sonex1517 » Sat Feb 07, 2015 3:53 pm
Hi everyone,
I am building Sonex 1517 that had matched hole parts. I am now trying to install the pitch trim rear spring attachment eyebolt re-enforcement per page 6 of the pitch trim instruction sheet.
The re-enforcement plate depicted in the instruction sheet is 2" by 1 1/2". In my Sonex with the matched hole parts there is no physical way this part can be installed as depicted.
There is less than 1" at the top, and I am now puzzled as to what to do to re enforce the eyebolt. (Date on the online sheet is Rev C 3/1/2013)
I can possibly get a 2" by 3/4" piece of .025" material in there. Just not sure if this is enough re-enforcement. I did email tech support.
Has anyone else had an issue with this?
Chicagoland
N1517S reserved
Aero Estates (T25)
First flight 10/10/2015
325+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Re: AeroConversions pitch trim installation with matched hol
Postby Sonex1462 » Sat Feb 07, 2015 10:40 pm
I have been puzzling over the same thing for the last couple of days.
My kit was not match drilled. I built my fuselage per the plans but now at this stage it appears to be rather impossible to install the reinforcement per the trim instructions.
I thought about putting a length on 1/8" X 1" X 1" angle over the top of the fuselage cross tie.
I am interested in what Sonex Tech support suggests.
John Stewart
Sonex 1462
John Stewart
Sonex 1462
Sonex1462
Postby Sonex1517 » Sat Feb 07, 2015 11:27 pm
See attached for my solution
Chicagoland
N1517S reserved
Aero Estates (T25)
325+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Postby Sonex1517 » Sat Feb 07, 2015 11:28 pm
Since the bungee is not used with the AeroTrim, I removed the hook for the bungee and put it behind the rear spar carrythrough with a doubler to re enforce it on the front.
Relatively easy.
Chicagoland
N1517S reserved
Aero Estates (T25)
325+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Postby MichaelFarley56 » Sat Feb 07, 2015 11:30 pm
Looks great Robbie! That's one heck of a picture!
Waiex #0056 - N569KM
Jabiru 3300A #1706
Return to Sonex Plans
