wingnut99 wrote: It looked like the weight would contact the upper and lower skin when the aileron is deflected in either direction. If so, is that a problem with it denting the skin outward?
N190YX wrote:You don't need to put a string in the conduit when you install it, you can to what the Electricians do and use compressed air to blow a string through the conduit when the time comes to pull wires through.
Bryan Cotton wrote:
With the acro ailerons you can't balance to 100%, i.e. aileron level.
Can someone explain the reason why it is called out in the plans to fully balance the standard ailerons (within 1/2" of level at the trailing edges) while the more massive acro ailerons do not require full balancing other than being consistent with the left and right's imbalance? I'm glad this topic came up now as I've built my wing boxes for the acro aileron option but, as I get ready to make control surfaces, I'd like to pause to understand the rationale on the balancing.
Paul
