Fuel line fitting
Discussion for Waiex builders on specific plans page experience. These posts are limited to technical suggestions such as assembly order, challenges, or techniques related to specific plans pages.
Re: Fuel line fitting
Postby Skippydiesel » Wed Apr 03, 2024 6:15 pm
In this conversation there seems to be a failure to understand the difference between fuel pressure and flow (volume).
Carburettor engines operate, for the most part, on fuel flow ie little pressure
We often use fuel pressure as a handy gauge of fuel system delivery efficiency/health, however you can have good pressure and poor/minimal flow.
In an aircraft fuel system it is generally easier (cheaper/simpler) to measure pressure than flow, although fairy recent innovations have made this observation less applicable than the past.
I am an advocate for transparent wall filters, so that the pilot can have some hope of visually assessing filter blockage.
Note: a blocked filter may have minimal impact on fuel pressure but restrict flow to the point of reduced engine power or failure.
Skippydiesel
Postby Bryan Cotton » Wed Apr 03, 2024 10:42 pm
builderflyer wrote:But, I can't say, though, that I've found a direct connection between measured fuel flow rates and the ability of the fuel system to produce "burps", or not.
Art,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,,Jabiru 3300 #261
Art,
I really believe the burps are all about heat. I'm on a quest to get rid of the burps and the excessive heat buildup in summer. I definitely agree with you about experimenting. That is part of the fun and to make your airplane a little better is very satisfying.
Return to Waiex Plans
