Hello SonexBuilders.net!
Due to popular demand, Sonex Aircraft is currently designing Rotax 912-series engine mounts for Legacy Sonex, Waiex and Xenos Aircraft in both Standard and Tri-Gear configurations. Design of both mounts is nearly finalized and customers are encouraged to pre-order now, as Legacy Rotax mounts will be special-order items not kept in regular inventory:
http://www.sonexaircraft.com/eshop/cart.php?target=category&category_id=452
- Legacy Rotax 912-series Engine Mount (Std Gear)
- Legacy_Rotax_Mount-Std-300.jpg (39.7 KiB) Viewed 10184 times
http://www.sonexaircraft.com/eshop/cart.php?target=product&product_id=17646&category_id=452
- Legacy Rotax 912-series Engine Mount (Tri-Gear)
- Legacy_Rotax_Mount-Tri-300.jpg (50.34 KiB) Viewed 10184 times
http://www.sonexaircraft.com/eshop/cart.php?target=product&product_id=17647&category_id=452Installation will require the SNB-P53-01 Rotax Attach Bars originally developed for B-Model Rotax installation:
- SNB-P53-01_Rotax_Attach_Bar-300.jpg (41.31 KiB) Viewed 10184 times
http://www.sonexaircraft.com/eshop/cart.php?target=product&product_id=17645&category_id=452A set of Qty 8 ACV-P01-19 AeroVee Rubber Shock Mounts will be needed:
http://www.sonexaircraft.com/eshop/cart.php?target=product&product_id=16774&category_id=452All Rotax engine installations (Legacy and B-Model) require the use of a 1-3/8" prop hub extension. Sonex Aircraft recommends Saber Mfg. PN
1.375x5 Rotax 912 or equivalent, currently priced at $295 by Saber:
http://www.sabermfg.com/Note that, while B-Model cowlings are designed to accommodate Rotax installation, Legacy cowlings were not designed with the Rotax in-mind, and modifications may need to be made by the builder.
Sensenich has already designed a prop for Rotax 912/Sonex or Waiex installations on B-Model and Legacy aircraft:
http://www.sonexaircraft.com/kits/props.htmlAs-always, please feel free to contact us with questions!
Mark Schaible
General Manager
Sonex Aircraft, LLC
phone: 920-231-8297
fax: 920-426-8333
http://www.SonexAircraft.comhttp://www.AeroConversions.comSales Info:
sales@sonexaircraft.comOrders:
orders@sonexaircraft.comAccounting:
accounting@sonexaircraft.comTech Support:
tech@sonexaircraft.comBuild a Sonex Aircraft in Your School!
Check out the Sonex Education Initiative:
http://education.sonexaircraft.com/
