Taper pin philosophy
Postby Carlos Trigo » Tue Jun 30, 2020 4:14 pm
In the type of aircraft homebuilding I’m used to (RV’s), there is no use of taper pins, all is done with AN bolts.
Does anybody know what’s the philosophy behind using taper pins instead of bolts?
Carlos
Carlos Trigo
Re: Taper pin philosophy
Postby Sonex Foundation » Tue Jun 30, 2020 5:56 pm
President
Sonex Builders and Pilots Foundation
http://www.Sonexfoundation.com
Sonex Foundation
Postby Carlos Trigo » Tue Jun 30, 2020 6:29 pm
Do you mean that the use of a taper pin, instead of a bolt, is “to reduce the potential for a sloppy connection “?
Carlos Trigo
Postby GordonTurner » Tue Jun 30, 2020 10:32 pm
Yes. In tube to tube connections
Postby sonex892. » Wed Jul 01, 2020 4:28 am
They have been used with success for spar bolts also. The new old addition to the Sonex line of aircraft, the Sonerai. Uses 6 taper pins in lieu of bolts to hold the wings on.
Sonex 892
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Return to Xenos
