GRT EIS & Princeton fuel probe cal
Postby trwolf » Mon Jun 08, 2020 1:19 pm
Has anyone installed the GRT EIS with the Princeton fuel probe? Interested in just how you solved the EIS portion of the calibration process. I have done this with a 4 gal tank and what a pain. I am thinking of simulating the fuel tank fill and empty process with a 2 gallon can instead of a Xenos fuel tank. Better yet if someone already has accurate numbers for the Legacy tank and EIS programming?
Well, I filled and drained the 16 gallon (make that 15+ gallon) tank about 4 times and then gave up and settled for a compromise readout that tells me 3 gallons when I actually have 4 and 7 gallons when I have 8. OBTW, if you have the craft in level flight position and try to fill to 16 gallons, well most of you have probably already figured out how to spill a 1/2 gallon of fuel all over the place. Really glad I installed an over flow tray in the fuel fill box.
trwolf
Return to Xenos
