Spaceman wrote:If I remember correctly I had to get a few bronze bushings from Mcaster Carr since ACS didn't have them. There were also a couple that I remember having to buy slightly long and then filing down to the correct length, which was tedious but it worked.
Kitfox93eg wrote:The McMaster part number is 6338K411 like others have posted you will need to shorten the bushing for proper clearance. The plans call for 5 to 15 thousands side clearance I used a lathe but a file would work also.
They also had the bushings for the B control stick that number is 6338K421
If you have never used McMaster Carr you need too they have everything.
Ed Grasso
