Y tail angle
Y tail angle
Postby Carlos Trigo » Fri Mar 06, 2020 4:27 pm
Guys
I am building the XENOS tail, and to install the Total Energy multi-function probe I need to know the angle that the tail surfaces make with the horizontal plane.
Does anybody know this angle?
Is it around 45º?
Carlos
Carlos Trigo
Re: Y tail angle
Postby XenosN42 » Fri Mar 06, 2020 5:05 pm
I installed my total energy probe as shown in this image of the last rib on the stabilator: Image
Installed this way the probe points directly into the airflow. I don't know the angle the tail surface makes with the horizontal plane, but I don't think it makes a difference. Just install as the image shows and you'll be great to go.
-- Michael
OneX N169XE
XenosN42
Y tail angle
Postby Carlos Trigo » Fri Mar 06, 2020 6:29 pm
Hi Xenos42
Thanks for your answer and the picture of your installation.
The manufacturer of the multi-function (pitot + static + TE) probe recommends to install the probe and its adapter with the 3 pressure ports in a vertical position, pointing upwards.
That’s the reason I want to install the adapter in the same place you installed yours, but with the barbed ports (3 in my case) clocking vertically when the tail surface is installed in its Y angled position.
Carlos
Carlos Trigo
Re: Y tail angle
Postby Area 51% » Fri Mar 06, 2020 7:05 pm
If the Xenos is the same as the Waiex, the stabilizers are 35deg from horizontal. If you have the Y fitting that attaches to the tail post, you can get your information from that.
Re: Y tail angle
Postby Bryan Cotton » Fri Mar 06, 2020 9:13 pm
The 3 view on the plans is a good place to measure the angle. The plans are drawn in AutoCAD so the picture is accurate. I measured it once for my Waiex but don't know the number, but of course Randy just gave it.
Y tail angle
Postby Carlos Trigo » Sat Mar 07, 2020 6:23 am
Thanks guys
Carlos
Enviado do meu iPhone usando o Tapatalk
Carlos Trigo
Y tail angle
Postby Carlos Trigo » Sun Mar 08, 2020 12:02 pm
Following Bryan’s suggestion, I measured the angle in the 3-view drawing, and it gave me 38º
Carlos
Carlos Trigo
Re: Y tail angle
Postby Area 51% » Sun Mar 08, 2020 3:32 pm
Not that 3deg is a lot, but just out of curiosity, did you measure the angle of the front spar on the print, or the rear? And on what page?
The reason I ask is I just measured the angles on my Waiex print (page T-07) and got two different readings. The rear Y came to 110deg. The front (hockey sticks) showed 104-105ish. Take those, subtract from 180, divide by two, and you get both answers. 35 and 38.
Now, I don't believe there is a twist built into the tail. What I do believe is the picture of the front attach point on T-07 is more of a rendering than a print. I think the amount that the hockey sticks angle rearward causes an "apparent" angle on that page.
For what it's worth, when I gave the 35deg measurement, it was on the airplane with a digital level.
On the other hand....the Xenos might be different.
Bored and curious here @Area 51%
Y tail angle
Postby Carlos Trigo » Sun Mar 08, 2020 7:56 pm
Hello Area51%
I measured it on page XNS-B01, but in fact these 3 degrees are not relevant for this case.
So, thanks anyway
Cheers
Carlos
Carlos Trigo
Re: Y tail angle
Postby racaldwell » Mon Mar 09, 2020 12:30 pm
Carlos,
I guess you have a fixed probe? I just thought they were all like the one I bought, it is removable. I am thinking it can be clocked in any way. I remember it has o-rings on the end but don't remember if was keyed. It's been too many years since working on the tail. I haven't looked at the probe since then.
Rick Caldwell
Xenos 0057
racaldwell
Return to Xenos
