racaldwell wrote:Carlos,
I guess you have a fixed probe? I just thought they were all like the one I bought, it is removable. I am thinking it can be clocked in any way. I remember it has o-rings on the end but don't remember if was keyed. It's been too many years since working on the tail. I haven't looked at the probe since then.
Rick Caldwell
Xenos 0057
Carlos Trigo wrote:No, I have a removable probe as well.
The manufacturer (ESA Systems) recommends that the probe be used always with the TE sensor pointing upwards.
Further, they also recommend that the adapter (the female piece, installed solid inside the stabilator) be installed with the 3 barbed ports pointing upwards, like this
https://www.esa-systems.com/fileadmin/u ... einbau.jpg
That is the reason why I wanted to know the angle of the stabilator with the horizontal, exactly to clock the position of the adapter which is to be rigidly installed inside the stabilator.
Problem solved!
Carlos
