Stewart - Sonex 1462 - Progress Report
Postby Sonex1462 » Wed Jan 01, 2014 10:13 pm
Today was a big day. I started the wing rigging. All I did was level the fuselage and insert the wings. I inserted the pins in the 3 alignment holes.
John Stewart
Sonex 1462
Tri-Gear, Aerovee, Dual Controls
John Stewart
Sonex 1462
Kit, Aerovee, Tri Gear, ST Controls
Website: http://stewartaircraft.net
Sonex1462
Re: Stewart - Sonex 1462 - Progress Report
Postby MichaelFarley56 » Wed Jan 01, 2014 10:42 pm
Looking great John! Take your time, measure twice, and enjoy the rigging process! It looks like you're building a beauty there!
Waiex #0056 - N569KM
Jabiru 3300A #1706
Postby Sonex1462 » Thu Jan 02, 2014 9:27 pm
Thanks Mike
John Stewart
Sonex 1462
Sonex1462
Postby Sonex1517 » Thu Jan 02, 2014 9:30 pm
Way to go John!!
Robbie
325+ hours
Postby Bryan Cotton » Thu Jan 02, 2014 11:20 pm
Very motivational, thanks for posting.
Postby Sonex1462 » Sun Feb 09, 2014 1:11 am
It has been a while since I last posted on my progress.
I have finished my wing rigging. I did have a problem with part of the right side main spar attach bolt hole. Some how the final hole did not follow the pilot hole in the forward vertical angle and the front part of the forward attach block. The final hole had a small 'divet' of about 10% from the pilot hole. The hole through the aft side of the forward attach block, spars, aft attach block and aft vertical angle was perfect. So I replaced the forward vertical angle and forward attach block. I mated the wings outside of the fuselage. I made a bushing that is 3/8th OD and 1/4th ID. I used the good aft holes as a guide and inserted the bushing and drilled the 1/4th pilot hole through the forward attach block. I then used a 3/8th drill bit where I had dulled all but the first 1/2 inch to drill the 3/8th hole through the forward attach block. I put the wings back in the fuselage in the proper position. I then drilled the 3/8th hole through the forward vertical angle from the aft to the forward. Again I used the 3/8th drill bit I had dulled.
Success!! I now have very tight perfect holes on both sides.
I have also finished installing my tail. Including the fairings.
Today I was able to install my main landing gear with hydraulic brakes and wheels.
The wing rigging problem was a bummer for a while but I feel like I am back on course with good motivation.
John Stewart
Sonex 1462
Tri Gear, Dual Controls and Aerovee 2.1
John Stewart
Sonex 1462
Sonex1462
Postby Sonerai13 » Sun Feb 09, 2014 9:48 am
Looks great John! Keep up the good work!
Joe
"Fortes Fortuna Adiuvat"
Joe Norris
Sonex N208GD (S/N 450)
Sonerai II N13NN (S/N 1206)
Sonerai13
Postby Sonex1462 » Sun Feb 09, 2014 5:00 pm
Thanks Joe
John Stewart
Sonex 1462
Sonex1462
Postby Sonex1462 » Sat Nov 29, 2014 11:16 pm
Today I powered up both EFISs
Next I need to connect the RDAC, AHARS, etc
John Stewart
Sonex 1462
John Stewart
Sonex 1462
Sonex1462
Postby ScottM-Sonex1629 » Sun Nov 30, 2014 4:02 pm
Looks great John! I am using the Xtreme (just one) in my panel as well, really like the functionality, looks and small package! Your getting closer to being finished.
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Return to Photo Album
