I posted in the other thread that the WD40 was like a miracle for running the tube through the grommets. I am mentioning it here for continuity in this thread. Spray a bit on a paper towel, wipe the tube, pull it through.
Time to rig the mini rudder and cables. I didn't take a picture, but I had to clearance the strike plate on the back edge where the drive horn hit. I also made the aft bottom rivets flush, and put a little notch on the drive horn to clear the forward rivet. I had to take a small amount of material off the right side drive horn. To line up the mini rudder I did 3 things:
1) Line it up with the tail spring
2) Sight down the top of the rudder and fuselage
3) use this nifty tool on both sides. I line up the back edge of the rudder with one end, and when the far end of the ruler just touches the fuselage the stick just touches the aft edge of the tailcone.
Next I clamped a couple pieces of 1/8" scrap to the mixer. I then wedged a couple .032" shims in there and the mixer was centered for yaw.
I put a piece of blue tape on the idler pushrod. I marked full forward and aft, then made a mark halfway between the two. I clamped the stick assembly in the halfway spot.
