Cotton Waiex 191 - N191YX
Re: Cotton Waiex 191 - N191YX
Postby Sonex1243 » Sun Oct 25, 2015 9:51 pm
Looking good Bryan. Did you up size the wing blocks all the way?
Ken S
SONEX #1243 N424SX (reserved)
Tail complete, wings done
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Bryan Cotton » Sun Oct 25, 2015 10:12 pm
Not yet Ken but I will. I drilled the blocks by themselves in a drill press vice. Adam did a couple of them the same way. I figure before I drill up I need to figure how to clamp the whole spar on the drill press table. Thanks also Michael, Ken and John for the encouragement.
Postby Bryan Cotton » Wed Oct 28, 2015 10:39 pm
I drilled the three 1/4" holes in the spar. I used an egg cup drill bushing holder to get to 3/16" but did not have a 1/4" bushing. I drilled three through holes in a bar to 3/16" diameter. Then I drilled most of the way down with a 1/4" bit.
Next I located the block with a 3/16" bit (which is why I didn't go all the way with the 1/4"), clamped in place, and drilled. The block guides the drill.
Obviously I pulled the 3/16" bit out after I clamped it down.
Postby Bryan Cotton » Thu Oct 29, 2015 11:09 pm
Got my spars rigged up in my drill press. Used my truck canoe rack, plus a step stool, wood blocks, and a bottle jack since I had to offset it.
My last pass was with a .3725 reamer. Had to gently tap the bolt in. Success! Halfway done, left side is still 3/16".
Postby onex28 » Fri Oct 30, 2015 8:35 am
Way to go Bryan. That's why I enjoy the building process, you get to devise all sorts of ways to jig up a part to perform an operation.
David
onex28
Postby Bryan Cotton » Sat Oct 31, 2015 2:44 pm
Thanks David!
To check for trueness, I did 3 things. Check for square on one axis:
Then the other:
Note I used a reject wing block to help. Remember what I said about allowing for saw kerf? The third check is the 3/16" bit I used to drill the blocks should go in and out without binding.
Here is a super-interesting video of me drilling up the blocks on the left side:
http://www.youtube.com/watch?v=a5nJ0gXonHk
Maybe not that interesting. But I will point out the box holding the camera has my new Gaugepod wingtip light mounts. I haven't opened it yet.
I can push both bolts about halfway in by hand with light oil on them. Then I have to tap them in with the little plastic hammer. I am very pleased.
Postby onex28 » Sat Oct 31, 2015 9:29 pm
Good video Bryan. Others will learn by it. You will like the Gaugepods, they are well made. I have them on my Onex.
David
onex28
Postby Bryan Cotton » Wed Nov 04, 2015 12:25 am
Root rib angles:
I am waiting for new, shorter flush bolts to come for the spar mount angles. The specified lengths were very long.
Postby Bryan Cotton » Tue Nov 10, 2015 10:26 pm
Adam set his first 11 real AN470AD5 rivets today. We practiced on scrap first.
http://youtu.be/tNlD0cddsKM
Some of you may wonder why 11- he smiled one up real good and we had to drill it out. Perfect. You can't really learn to rivet unless you make mistakes. Probably true for anything worth learning. I tried to teach that lesson on the scrap but a real experience is better.
The 10 keepers are awesome.
Postby Bryan Cotton » Wed Nov 11, 2015 12:21 am
Adam's riveted stiffener and some spacers. I was trying to transfer holes from the web to the spacers but it was a bear to clamp. Ruined one spacer. Then I thought to make a mild steel tool, which you can see in the picture. I will try it out another day.
Return to Photo Album
