Cotton Waiex 191 - N191YX
Re: Cotton Waiex 191 - N191YX
Postby Bryan Cotton » Sat Jun 27, 2015 12:08 am
Darick,
It is open to anyone willing to subject themselves to rework!
Postby Bryan Cotton » Sat Jun 27, 2015 1:01 pm
Marked up aileron skins. The drive ribs, clecoed together without the horns, make a nice stable way to set the height while marking.
As a sanity check I put the skins together, mirrored in 3 orientations and verified the markings were the same on both ailerons.
Postby Darick » Sat Jun 27, 2015 6:21 pm
Bryan Cotton wrote:Darick,
Bryan,
I did the 40" mistake too and had to redo that area, which I also saw on this photo album. So I am very qualified to join.
I'm now in the process of reviewing all the entries in your album about the fuselage construction to avoid future reworks!
Thanks for documenting your project so well.
Darick
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Postby kevinh » Sat Jun 27, 2015 8:39 pm
Hi Bryan,
Looks great! How do you plan to cut the slots for the control horns on the ailerons? I can only think to drill the radius holes at the end and then to use a cutting wheel. But I kinda hate the wheel due to nick possibilities. :lol:
kevinh
Postby Bryan Cotton » Sat Jun 27, 2015 8:54 pm
Kevin,
I have the same plan as you. I also use the Force to guide my hands. Also I usually cut a little shy of the line and use a mini file and/or an angle sander.
Postby Bryan Cotton » Sat Jun 27, 2015 11:14 pm
Kevin,
The straight dremel guide might work for this. I think I'll try it.
viewtopic.php?f=34&t=1949
Postby kevinh » Sat Jun 27, 2015 11:38 pm
Great idea! I'll try a similar tool.
kevinh
Postby Gripdana » Sun Jun 28, 2015 8:18 am
I used a nibbler and a file. Just my two cents worth.
Dana Baker
Scratch Built
First Flight March 8, 2015
Gripdana
Postby aferddaberts » Sun Jun 28, 2015 12:20 pm
Hi, Bryan,
I just got through sending a long message to the Forum regarding the "40 inch mistake" Then when I clicked on Submit, I got the "not signed in correctly" notice. So, not going into a long version again, I'll just ask you about it. I,m just about finished with my fuselage, and if somewhere along the line I've made that mistake, now would be the time for me to know about it.
Thanks Bryan,
AL Roberts W0209
aferddaberts
Postby Bryan Cotton » Sun Jul 05, 2015 6:10 pm
No progress last week. Was at summer camp with the Boy Scouts. Great week! WX was mostly good. Mosquitoes were a bit thick.
So to trim my aileron skins, I first cut the corners with a cutoff wheel in my 4" grinder. Then out came the shears, then the angle sander, then the files.
For the drive horns and counterweights I got out the dremel. My nibbler is too big.
Here they are. Sharp before the edge finishing. Those parts have blood on them!
Return to Photo Album
