by ScottM-Sonex1629 » Mon Mar 24, 2014 6:17 pm
Ryan,
Funny you should ask since I was reading your post on "how did you do it?" Yesterday...
Yes mostly working solo, will get help from family if it's a big lifting task, etc. I'm a tall guy and have a pretty wide wingspan...so I ended up rotating the aft f-box on it's side, then grabbing the opposing ends of the turtledeck skin and carefully inserting the aft end in between the rear section of the longeron and skin and working my way up to the front edge. Probably took less than 30-45 seconds. I then carefully bent the skin up and inserted the opposite side in using the same technique. Once done I rotated the whole assembly back upright. Before inserting the turtledeck skin I marked the 1" depth line from the edge so I would know if the skin was in far enough or too far.
Scott Meyer
Sonex 1629 - Sold...9/2019
