by Bryan Cotton » Wed May 27, 2015 8:15 am
Thanks Kevin! Since you are taking notes for your build, definitely make your phenolic blocks to your parts and not just to the print. I used a transfer punch to transfer holes from my flap bracket to a piece of aluminum scrap. First set we made by measurement and people are just not accurate enough. If you are not going the machined angle kit route, I would make the template to the print and make all the angles and phenolic to the template.
The advantage of the template is you can rivet the angles in and still make phenolic blocks that will bolt up!
