Thanks Scott and Glenn! I agree Scott that there is going to be no extra flap position with the center controls. I am good with it!
My last picture of my master cylinder mount was poor. Following the plans I have zero edge distance on the bolts. Perhaps the dimensions of the master cylinder have changed or something. So, I came up with my own design to keep moving forward. Stock Sonex on the left, mine on the right.
![Image](http://i198.photobucket.com/albums/aa72/Aerowerk/734619AE-30F0-4AD1-80AD-7244278E18D9.jpg)
This is my own permutation, not blessed by Sonex or guaranteed by myself. I used thinner (.050") but sterner (7075-T6) stuff and did a little fancy brake work. I can tell you that if you ignore the proper bend radius on 7075 it will break! After that little lesson I cleaned up my act and it came out good.
AN5 bolts are specified for the MC but they are more like 9mm, or 21/64+ if you prefer. I made some shims for now out of flashing, but will look for better fitting bolts. The flashing shims let me locate the holes nicely.
