by Rynoth » Wed Jun 11, 2014 6:18 pm
Bryan, it's either your photography or your polishing job (or both), but the pics of your polish job look fantastic. That said, I'm using the Nuvite brand pads, and I'm usually done after about 3 passes of F9. But I've not gone all the way with C grade yet (just 1 pass on my fwd side panels).
I've washed 3 of my pads 1 time and reused them to good effect. So far I have 3 F9 pads, 1 C pad, and 1 to-be-used S pad. I expect those 5 pads will be more than enough for the life of my polish job.
In terms of polish, my F9 polishing is done save the 2 floor skins, and I've used just over 1lb of polish. 1.5lb should be plenty for all my initial F9 polishing.
All that said... the polish job in your photos looks better than mine! But you'll be here next week and can be the judge in person.
Edit: we may be using the term "pass" differently. When I say 3 passes, I mean I applied F9, and for any particular location it went through a 40-60 second cycle of buffing/drying out, 3 times. In terms of passing over the entire piece, (bit by bit) I've been doing it once per grade of nuvite.
