Over the last few weeks I ordered some single stage paint, and prep materials. Based on some others posts and research I chose to use PreKote for preparing the Aluminum for paint. I chose to take the tail apart and prep individually and paint the pieces separately.
The PreKote is easy to use, clean the aluminum first, then spray the PreKote on the surface, and scrub/scour the surface with a red scotch brite pad. Spray a second time and repeat the process, then rinse with water then let dry. I did this yesterday.
![Image](http://i305.photobucket.com/albums/nn218/STL-Scott/Sonex%201629/7ce92c96a4d7110950cdcfcebfd0bdb9.jpg)
The directions say to prime within 24 hours so today I got out my Sherwin Willams (automotive paint) Dimension DP800 epoxy primer. It's a 3-part primer. Good stuff. I was worried it had been on my shelf too long but it stirred up okay and seems to be curing just fine. (8-parts epoxy primer, 4-parts reducer, 1-part hardener).
I have sprayed out the rudder, elevator, vertical stabilizer and the fairings. Still need to remove and prep/prime the horizontal stabilizer.
![Image](http://i305.photobucket.com/albums/nn218/STL-Scott/Sonex%201629/fd6e692938f7dde5f5fd6b7197bc530e.jpg)
![Image](http://i305.photobucket.com/albums/nn218/STL-Scott/Sonex%201629/3952e9518c5cc6fbe795049134f9791b.jpg)
![Image](http://i305.photobucket.com/albums/nn218/STL-Scott/Sonex%201629/df7396af3aec3fc0df8d6715cc10de2c.jpg)
When I do the color coat my plan is to make a small booth inside my garage. I've painted three cars like this before, and based on how small of the parts I needed to prime today I didn't bother with a controlled environment. I am in no rush to top coat, so I will scuff up the primer before applying color.
