Made one step forward two steps backwards today. Thought I had everything wrapped up with the glare shield and instrument panel assembly (was drilled out to final rivet size) and figured it was time to test the fuel tank.
One step back...it didn't want to come "forward" enough in the filler box. WTF.
took the glare shield completely off, and tried dropping the tank in with the straps in place. It fits fine, but I can see the top of the tank is sitting way higher than where my glare shield top was. Another step backwards.
After a few choice words...a beer, and some downtime...I figured there has to be a simple solution. I want to get the tank to fit before I need it to fit, and it's too far into the build to find a solution.
Realized if the the glare shield would sit up higher and the sides came in a little under the longerons, it would work. So I had to redrill several holes along the glare shield and longeron. Will make a doubler for underneath this area. When I got to the firewall, I had to find a different solution. The firewall to glare shield angles were already final drilled. Remade the two side angles, and used the holes from the bad piece to transfer to the new piece on the glareshield side. Then back drilled from the firewall into the new piece. Everything fits tight now,and looks acceptable.
So in the end it I accomplished what I wanted to do today, but learned that maybe the fuel tanks are a bit too tall per plans? Hard to say.
Advice for others, fit the fuel tank before you begin drilling the glareshield to the longerons. You'll thank me later.
