Cotton Waiex 191 - N191YX
Re: Cotton Waiex 191 - N191YX
Postby Bryan Cotton » Sat Nov 21, 2020 11:51 pm
... continued from the prior page for the 5 picture limit:
Here is my panel with labels installed.
Switch box, with old buttons underneath:
The PTT ICS lets you turn the squelch all the way up, so voice activated ICS doesn't work. My intercom is an SPA400N, and this feature is for noisy cockpits.
Breakers and switches.
Postby Bryan Cotton » Wed Dec 09, 2020 12:17 am
My panel is in. Just need to hook up a bunch of grounds, terminate a few wires, do another checkout, and I'm going to rivet it in.
Postby WaiexN143NM » Wed Dec 09, 2020 2:40 pm
hi bryan,
Thanks for the update. Keep at it and get it finished!
Not sure if eaa airventure 21 will happen, but you may have it done by then.
the paris airshow in june2021 just got cancled.
im keeping my fingers crossed.
be safe and healthy to everyone.
Michael.
Postby Bryan Cotton » Wed Dec 09, 2020 3:05 pm
Flying to Oshkosh next year is my goal! Same as the last 5 years.
Postby Bryan Cotton » Wed Jan 20, 2021 1:14 am
Here's a little milestone - power on!
Postby Darick » Sun Jan 24, 2021 1:44 pm
Bryan, the photos aren't available anymore. Have you reposted them again by chance?
Bryan Cotton wrote:Here is our new portable jack. It has wheels and disassembles for easy storage in the back of the Waiex. Not sure what all the jacking fuss was about.
In the 3 point attitude the plate was 8 degrees nose down and the airplane was 9.5 degrees nose up. So, our hole pattern needed to rotate 17.5 degrees. We used this simple setup.
Afterwards we will cut out the red line and have a new template.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Postby Bryan Cotton » Mon Jan 25, 2021 2:02 pm
Darick wrote:Bryan, the photos aren't available anymore. Have you reposted them again by chance?
Darick,
Between having been screwed both by photobucket and postimage, I've sort of lost interest. If we had storage on the forum like all my other forums have, I'd be posting a lot. Because of our limited storage I have been super-downsizing my pictures to save space. Seems like too much effort. But if a member has a particular request for an old photo I'd dig it up.
John Monnett said I should do less posting and more building. I think he's right!
Postby Darick » Mon Jan 25, 2021 4:57 pm
Bryan,
My keyed switch similar to yours on the panel, is wimpy. I've already bumped it while flying and turned off everything. Of course the engine kept running thanks to the primary ignition set up.
Does your's have a good detent that keeps it in position firmly? If so, could you share that info with a source and p/n?
Kerry says I could buy the one used in the Subsonex, which I assume is of high quality, for $35 (or so I forget the exact amount).
Darick
(returning to flying despite the crummy health situation)
Darick Gundy
Sonex #1646
N417DG
Darick
Postby Bryan Cotton » Mon Jan 25, 2021 6:37 pm
Darick,
My key switch only enables the starter. Somebody here had that good idea. The master switch is the red handle and is mechanical as I detailed in this thread:
viewtopic.php?f=6&t=2009
Postby Bryan Cotton » Tue Jan 26, 2021 5:42 pm
If you have sharp eyes, you may have noticed my ball was out in that video.
I leveled the airplane to fix this.
After slotting the mounting holes I got it adjusted.
Next up - need to solder up my headset jacks and PTT switch connectors.
Return to Photo Album
