Cotton Waiex 191 - N191YX
Re: Cotton Waiex 191 - N191YX
Postby Bryan Cotton » Thu Apr 18, 2019 10:25 am
We decided to have the baffle backing plates stick up higher than the baffles. Adam has made paper patterns and has converted about half of them to metal.
I don't think we can quite catch Ryan unless he has another kid. It is funny how despite delays on both sides we have more or less kept on a similar schedule to first flight.
Postby Rynoth » Thu Apr 18, 2019 11:00 am
Bryan Cotton wrote:I don't think we can quite catch Ryan unless he has another kid. It is funny how despite delays on both sides we have more or less kept on a similar schedule to first flight.
Yea it seems like forever ago that I finished my baffles (because it was, about 3.5 years,) but it terms of build time it was only 230 more hours from there to completion. A decent bit of that was stuff like fairings, fiberglass work, polishing and paint (which you've already mostly done,) and dealing with Turbo SB, defunct ELT replacement, and quite a bit of troubleshooting with ignition, carb/throttle and instruments.
Postby Bryan Cotton » Mon Apr 22, 2019 10:11 pm
Some baffle progress.
Postby Bryan Cotton » Tue May 07, 2019 11:04 pm
Here Adam has finished the aft and side baffles including riveting.
We have one place where we need to glue a couple of rubber pieces together. We did a sample coupon using red RTV. Was impossible to pull apart.
Here is progress on my oil cooler baffle. I have it mostly riveted up.
Postby sonex1374 » Wed May 08, 2019 11:09 am
You can also use waxed rib lacing cord to stich baffles together. This works well and doesn't tear thru the silicon like safety wire will.
Jeff
Jeff Shultz
Sonex TD, 3300, AeroInjector
Kansas City, MO
http://www.sonex604.com
sonex1374
Postby Bryan Cotton » Sun May 26, 2019 10:00 pm
The baffles are slow going. My first oil cooler baffle was a bust. Working rev 2. I am going to need a couple of square to round adapters. I made a plug out of foam.
Next I made a female mold. I've done some more finishing since this picture.
A couple in progress baffle pics.
Postby Bryan Cotton » Mon May 27, 2019 7:26 pm
My wet layup is curing with a vacuum bag as I write this. I have it outside because the cheap HP pump mists oil.
Adam got this much of the front baffle riveted up.
Postby Bryan Cotton » Thu May 30, 2019 8:43 pm
My vacuum bagging was a success, except the wax job didn't prevent the layup from sticking to the mold. The part and mold are both destroyed. I guess this is validation for choosing a sheetmetal airplane.
So, now I am going back to nature's composite - aluminum and solid rivets.
The front left corner is a pain. I am dropping my standards, suspending my disbelief that it will work, and we will use this flashing patterns to make parts.
Postby RCfly46 » Fri May 31, 2019 1:15 pm
Bryan,
You are not "dropping" your standards; it's called a "revision," Standards V1.1 LOL...
Joe in SE Mich
Waiex 181 in progress
RCfly46
Postby Bryan Cotton » Sat Jul 13, 2019 12:21 pm
We are substantially done with the baffling. I'll have to get some pictures.
Here is my concept for the breather. I have glued in a short length of tube and will use silicone hose to route it out to the bottom. I am going to rivet on this baffle with solids. I am debating doing the Tony Bingelis thing with stainless steel scrubbers but am not sure about that. I will probably make another baffle that rivets on top of the box and keeps the oil from having a straight shot at the holes.
It has been very slow lately. We got distracted by a $200 Buick Century for my younger son.
Return to Photo Album
