I am getting good at bending stuff. Here is the little Y thing:
![image.jpg](./download/file.php?id=1037&sid=6bcccdf840cadcccb32c93944ade7cb9)
- Little Y
- image.jpg (140.05 KiB) Viewed 39244 times
I set up the wood blocks so all 3 pieces were aligned the same.
![image.jpg](./download/file.php?id=1034&sid=6bcccdf840cadcccb32c93944ade7cb9)
- Y tail bending
- image.jpg (127.11 KiB) Viewed 39244 times
The doubler strap was thick. I used the hockey stick technique - pipe wrench on the arbor press, the old hummelbird fuselage alignment beam on the pipe wrench, Adam hanging on the arbor press handle, and I tweak it in with the pipe.
![image.jpg](./download/file.php?id=1035&sid=6bcccdf840cadcccb32c93944ade7cb9)
- Loooong lever arm
- image.jpg (97.04 KiB) Viewed 39244 times
The three pieces seem to fit well together and I got the 4.6 degree angle pretty good. Lots of holes to drill!
