Cotton Waiex 191 - N191YX
Re: Cotton Waiex 191 - N191YX
Postby Bryan Cotton » Mon Nov 19, 2018 4:25 pm
Seeking feedback on my plumbing:
Postby N111YX » Mon Nov 19, 2018 7:15 pm
That's probably the most direct fuel routing I have seen!
I'm sure you have a plan for the rubbing of the fuel line on the engine mount.
Is that an inline filter?
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby Bryan Cotton » Mon Nov 19, 2018 8:01 pm
Kip,
It is an inline filter:
https://www.jegs.com/i/JEGS/555/15034/10002/-1
Have some ideas on anti-chafe. The rubber carb mount has more flex than the fuel line.
Edit: I countersunk the outlet end of the filter so there would not be a corner to catch water.
Postby Darick » Mon Nov 19, 2018 9:11 pm
Then obviously you also decided not to monitor fuel flow. I asked a local two time RV builder about a fuel flow meter. He had a lose connection one time and landed immediately because of sudden unusually high fuel flow. He said it saved his life since the fuel was leaking in the engine compartment and was amazed he didn’t have a fire. That was enough reason for me to add one.
And since I had no experience with leaning, I thought it would give me an extra parameter to assure me I was in the advertised range.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Postby Bryan Cotton » Mon Nov 19, 2018 9:30 pm
Correct, no fuel flow. I don't think it is a super important measurement. The Pawnees and the Arrow I used to fly had them, but nothing else.
Everything you add is another potential failure.
Postby Bryan Cotton » Tue Nov 20, 2018 1:58 pm
One of the issues I had was my mixture control hit the CDI. So, I made another angle spacer.
The first one was 30 degrees. That was too much so I made a 20 degree one.
It's a miss! Onto the next task.
Postby Bryan Cotton » Tue Nov 20, 2018 8:29 pm
I did a little video of an interoperability test - mixture, throttle, fuel shutoff.
Postby dtwolcott » Wed Nov 21, 2018 10:32 am
Brian you are a great experimentalist. Just goes to show if you make enough mistakes eventually you will get it right, you just have to be persistent. I appreciate your sharing of your ideas.
Don
Don
Waiex 132 N132YX
3MY
dtwolcott
Postby Bryan Cotton » Wed Nov 21, 2018 1:17 pm
Thanks Don! Also for the record those are all unplanned design features, not mistakes!
Postby Bryan Cotton » Sun Nov 25, 2018 1:57 am
Rudder cable exit fairings. Between F and B- I became a true believer in annealing.
Return to Photo Album
