Sensenich prop engine high rpm's
PostPosted: Mon Oct 07, 2024 3:16 pm
by wingnut99
I had to replace my damaged Prince P tip but because of a 10 month wait I ended up buying a Sensenich 54 X 62 from Sonex. I didn't have any input on the specs because it's supposed to be optimized for my 3300 Gen 4 Jabiru with a Sonex airframe. I'm seeing 3500 rpm's on takeoff and climb if I don't throttle back. WOT on my Prince never exceeded 3300 unless I was in decent and the cruise speed was 135-140 at 3000 rpm's more or less. Sonex is questioning my tachometer but I haven't touched anything that should have changed it and with the slower airspeeds I'm seeing, it seems like the prop is just not the correct pitch.
My hanger neighbor says my engine sounds like it's turning faster when I takeoff than it used to. It's unnatural for me to throttle back on takeoff but I have no other choice until I can confirm that the tach is correct or not. I'll get the engine analyzer on it and check it against my Dynon HDX next time I have the engine running. Has anyone else experienced redline rpm's with a Sonex speced Sensenich?
Thanks for taking the time. Pat Murry
