Brand New Prince Prop De-Laminating.. Issue Resolved
Anything related to props
Re: Brand New Prince Prop De-Laminating.. Issue Resolved
Postby 142YX » Fri May 03, 2013 7:45 pm
I sent mine back on Monday too. I expect to get my new one in a week or two.
fastj22 wrote:I had painted the crush plate/nose cone but it chipped when I torqued the bolts. So I stripped all the paint off it. WIll leave it naked.
What did you use to paint your spinner that did not give you good results? I was hoping to paint mine..
450 hours and counting..
142YX
Postby fastj22 » Sat May 04, 2013 8:29 am
The same auto paint I used for the rest of the plane. The only problem areas were under the bolt heads. As I tightened the bolts, the paint gave way under them leaving unsightly chips. If I did it again, I'd mask off the surfaces.
Return to Propellers
