Johns wrote:Hi Guys, newby here, looking at the prop bolts I noticed there is no safety wire on the nuts. Is this how they all are? Seems to be only nylock (spelling) nuts on there.
Also can they be used over or should new ones be used?
John
radfordc wrote:When you set the torque on the prop bolts you have to add the "run on" torque for the nuts to the value specified by the prop maker. Nylocks require a significant amount of torque just to get them to run onto the bolt. Put a bolt in a vise and check to see how much torque is needed to turn the nut. Add this value to the specified amount of torque required for the prop bolts.
