Mike and Vic. The program is fairly simple to use. Its uses excel, just need to enter data in the fields such as RPM, speeds, HP, airframe type (slippery or draggy) diameter, type of wood etc. It took a little playing around with these fields to get the prop pitch I wanted. From this it will produce performance graphs and plotted airfoil section drawings for seven stations along with a table of coordinates for each station. I then copy these coordinates over to autocad manually to draw each station and from these drawings I make a plan view template of the prop shape. This is used to mark out the blanks. These could also be drawn by hand with a ruler and French curves.
- top templates
- IMG_0322.jpg (51.47 KiB) Viewed 10906 times
I do all the carving by hand but with powertools mostly.
1/Bandsaw to cut out the blanks and drill a centre hole which becomes the reference for absolutely everything.
2/Reciprocating saw to cut down to the station marks in the glued blanks, carefully stopping about 1/8" proud
- blanks with depth cuts
- IMG_0069.jpg (44.96 KiB) Viewed 10906 times
3/Electric plane to to rip it down to these cuts.
4/ File carefully to go down to final shape at each station, a vixen file would do for this,
5/Angle grinder with a 40 grit flap disc fitted to knock down the high bits.
- grinding off the high bits
- IMG_0314.jpg (39.77 KiB) Viewed 10906 times
6/Belt sander to bring it down to final shape starting with 40grit progressing to finer grades
7/Sanding by hand
I do steps 3,4,5 and 6 on the rear or bottom blade first then repeat the process on the top or front of the blade. As soon as I start with the belt sander on the top of the blade I start looking at the horizontal balance.
Thats how I have done it I'm no expert. It takes me about 60 hrs to do each one and its a dirty and dusty job
Sonex 892
