About time someone built a Sonex with this powerplant
For non Aviation related discussions.
Postby ihab » Sun Aug 24, 2014 7:38 pm
Symmetry is highly overrated. The Sonex rudder hinge is offset to one side and things work just fine. Humans have a heart on one side and a liver on the other. I once had a Ford Festiva that pulled to the side due to torque steer because one of the FWD driveshafts was longer than the other. Anyone who flies single engine prop planes deals with asymmetry every time that throttle goes forward. Embrace lopsidery!
And so it is that I present to you --
https://plus.google.com/100215158885259 ... czmpfAYk5X
Ihab
Ihab Awad, San Jose, CA
ihab
Postby Sonex1517 » Sun Aug 24, 2014 8:16 pm
I keep waiting to see either a turbine or a radial, personally....
Chicagoland
N1517S reserved
325+ hours
Re: About time someone built a Sonex with this powerplant
Postby radfordc » Mon Aug 25, 2014 12:57 pm
Maybe this will be the next big thing: http://www.foxnews.com/leisure/2014/06/ ... y-engine/#
Postby ihab » Tue Aug 26, 2014 10:05 am
Wow -- interesting! Thanks for the link! :)
ihab
Postby Direct C51 » Tue Aug 26, 2014 10:27 am
Sonex1517 wrote:I keep waiting to see either a turbine or a radial, personally....
The SubSonex is turbine powered.
Direct C51
Postby Sonerai13 » Tue Aug 26, 2014 3:08 pm
Robbie,
PBS makes a turboprop version of the SubSonex engine:
http://www.pbsvb.com/turboprop-engine-t ... ine-ts-100
Power rating is 180 Kw, which converts to about 241 horsepower. That ought to make the Sonex get up and go, huh! :)
Joe Norris
Sonex N208GD (S/N 450)
Sonerai II N13NN (S/N 1206)
Fortes Fortuna Adiuvat
Sonerai13
Postby Sonex1517 » Tue Aug 26, 2014 3:15 pm
Robbie,
Oooooh....rawr!
180 kilowatts = 241.383976 HP
325+ hours
Return to Off Topic
