Pneumatic pop riveter
Questions, recommendations, and all things tool related
Postby structurespilot » Wed May 16, 2012 1:00 am
Just found a Pnuematic pop riveter on ebay for 10 bucks. Used of course, but there's deals to be had if your patient!
Waiex Tail kit built! Working on Corvair engine core.
Norm (structurespilot)
structurespilot
Re: Pneumatic pop riveter
Postby rizzz » Wed May 16, 2012 1:06 am
Yep, definitely,
I bought nearly all my tools on ebay over the course of a 1-2 year period before I actually started building.
Gave me time to investigate what I was going to build, how I was going to build, find metal & other suppliers, make a worktable, setup my workshop and most importantly monitor ebay for bargains that pop up.
rizzz
Postby structurespilot » Wed May 16, 2012 1:24 pm
I 'am a structures AME for the last 13 years, so I'm pretty well set up for tools. But I have never needed a pneumatic pop riveter. We use very few pop rivets in certified aircraft. I guess I could have used our cherrymax gun at work, but the price was right. I also knew I wouldn't want to pull all those rivets by hand.
I'm patiently waiting for my Waiex tail to arrive, and setting up my shop at home.
Do the SS pop rivets provided by Sonex have a pull through stem? or does the stem remain in the rivet. If they pull through, has anyone tried filling the holes?
Also wondering about the flush rivet option I ordered, does that mean all the rivets on the skin will be dimpled, and then a flush pop rivet installed?
Norm.
structurespilot
Postby Andy Walker » Sun May 20, 2012 11:51 am
structurespilot wrote:I 'am a structures AME for the last 13 years, so I'm pretty well set up for tools. But I have never needed a pneumatic pop riveter. We use very few pop rivets in certified aircraft. I guess I could have used our cherrymax gun at work, but the price was right. I also knew I wouldn't want to pull all those rivets by hand.
Norm.
The stem generally stays in the rivet, though occasionally they'll come out, which does not affect them structurally. I'm not even sure one could pull all of those rivets by hand; the SS rivets are MUCH harder to pull than aluminum blind rivets; just pulling 5 or 10 by hand is quite a workout for your gripping muscles.
Andy Walker
Postby structurespilot » Sun May 20, 2012 3:00 pm
Thanks for the reply Andy. Do you know if the Flush rivet option, means all the external rivets, or just the L/E. Are they dimpled? I guess I'll find out soon anyway, when my tail kit arrives.
Norm
structurespilot
Postby MichaelFarley56 » Sun May 20, 2012 6:03 pm
To the best of my knowledge, the flush rivet option means most if not all external rivets are the CCC, countersunk variety. As you said, that's standard on leading edges but you'll end up doing the whole outside. How you accomplish it is up to you but when I did my leading edges, I left the rivet holes at #40 and did not updrill to #30. Once I dimpled the hole, the hole had opened up enough to accept the rivet. This kept things nice and tight. Just my experience...
Waiex #0056 - N569KM
Jabiru 3300A #1706
Postby Andy Walker » Sun May 20, 2012 8:38 pm
MichaelFarley56 wrote:To the best of my knowledge, the flush rivet option means most if not all external rivets are the CCC, countersunk variety. As you said, that's standard on leading edges but you'll end up doing the whole outside. How you accomplish it is up to you but when I did my leading edges, I left the rivet holes at #40 and did not updrill to #30. Once I dimpled the hole, the hole had opened up enough to accept the rivet. This kept things nice and tight. Just my experience...
That is a great tip, I'm going to try that!
Andy Walker
Return to Tools
