by DCASonex » Sun Jul 19, 2015 8:49 am
Bigger is better, but only if you have room for it. Two or more tables work well in smaller spaces. There will be times you need only one and all the floor space you can get. When built mine, I placed the wings on two 12 ft. long 2" square 14 Ga. steel tubes that were very straight, Those could easily have spanned between two smaller tables. Shimming up the tubes makes leveling and truing your setup very easy. Had duct tape in top face of tubes to protect aluminum. 2" is also deep enough to allow carefully flipping the wings with clecos installed. If doing that with clecos, strongly recommend putting those small plastic protective tips on them. If you then bump a cleco, it will not leave a small dent. Those plastic tips are pricey, but get a few,then go to CapPlugs catalog or website and order large quantity in same size and punch or drill holes in them to make your own. If large table (mine is 4 ft. x 12 ft.), and will need to move it, BIG casters are great help, but also be sure to have floor locks, preferably screw type that can also jack table perfectly level.
