As folks work on cold air induction and ram air induction, it is good to keep in mind the potential for carb icing. While lack of a venturi may decrease the potential for formation of carb ice, it doesn't eliminate it. There's still plenty of cooling resulting from vaporization of fuel in the carb, and this can be enough to cause the moisture in the induction air to form ice and to gradually block the induction air, maybe at a point downstream of the carb.
We sometimes say that the stock Aerovee/Aerocarb/Aeroinjector setup doesn't have carb heat, but it's probably more proper to think of it as constant, mild carb heat through induction of warmed air in the cowl. Induction of cooler ambient air will undoubtedly result in better engine performance (and ram air will also lead to a more modest increase), but without the ability to add warm air to melt any induction icing I think we should recognize that it is not without risk.
The Revmaster Revflow carburetor (designed very much like the Aerocarb) is available with a controllable bypass valve before the carb. It allows warm, filtered cowl air to be used, or cooler ram air. Here's what that setup looks like (from the Revmaster web site
http://revmasterautomotive.com/revmasteraviation/?p=206):
It wouldn't be hard to modify this to work with an Aerocarb, or build something similar.
