Crack in Tailwheel Bracket
Postby GraemeSmith » Tue Feb 18, 2020 6:23 pm
Reported to factory. But thought I would mention it here......
SNX-L03-31 - 6” Tailwheel
Time in Service – 285 hours as originally fitted to Sonex Serial 1153 by original builder.
Original Supply Date – not clear – originally supplied to the builder of the aircraft.
Symptom – slight “wallowing” of bracket to tube about the main vertical bolt.
Assumption – Top Hat bushings worn
Finding 1 – The 4 Top Hat bushings and bolt were in fair shape with no significant play between the bushes and the bolt. However the top hat bushes were actually wallowing in the machined - and worn - aluminum part that bolts to the titanium rod.
Finding 2 – See attached picture. I assumed that the “line” was a crack. Removal of paint showed it was probably a machining mark / limit (factory would know better). However closer inspection of “the line” and subsequent Dye Penetrant testing showed a hairline crack had started to develop and propagate in the vicinity of the machining mark. Also not clear about the orange tone / heat discoloration towards the bolt hole?
Action – replaced with new previously ordered.
Had the tailwheel been abused? Well sure - it came with some "wallow" already present when I bought the plane. I had ordered a new bracket to firm stuff up asap and when the bracket came in - went to fit it. But it was only when I removed paint from the original bracket that the crack became apparent. Till the paint was off - it looked just like a painted over machining mark.
Re: Crack in Tailwheel Bracket
Postby Matt541 » Tue Feb 18, 2020 6:51 pm
Good to know, something I'll add to my inspection while 541 is in the garage.
Thanks Graeme!
Matt541
Postby Mikegaydos » Tue Feb 18, 2020 8:07 pm
Any word from the mfr?
MikeG
Waiex-B #44
Lake Worth, FL
Mikegaydos
Postby GraemeSmith » Wed Feb 19, 2020 4:45 pm
Mikegaydos wrote:Any word from the mfr?
My picture currently at the machine shop for review.
Not had any other reports of this.
Postby Spark6 » Thu Feb 20, 2020 2:05 pm
Very interesting. Would be curious to know (and there may not be a way to ascertain), assuming no defect with the part, whether the cracking was as a result of prolonged fatigue, or a single (or few) instance of high load. (I.e., would a pneumatic tailwheel increase shock absorption and possibly prevent such damage?)
- Barrett
Prospective Sonex Driver
Spark6
Postby peter anson » Thu Feb 20, 2020 9:07 pm
It's fatigue. There appears to be a small step left by the machining operation that has formed a local stress raiser and landing gear parts are already pretty highly stressed. You could significantly improve the fatigue life of the part by polishing out the notch using a small cylindrical sanding drum, although if the new parts come painted it might be difficult to pick that a step is there. If you do all your landings on nice smooth runways it might never be a problem.
