SonexFactoryTech wrote:We are not sure the intent of Wes' comment.
Like I said, I just finished the FF test and so had/have many of the same questions you have.
Here is my take on it:
1) I'm sure Kerry is right.
2) My tests results were just OK, not stellar. The miniature fuel valve used on my Onex has a smaller orifice than the valve typically used on the Sonex/Waiex. You may be using a similar fuel valve.
3) There are simply too many variables for Sonex LLC to be able to quote a a deck angle for the test.
Examples:
What engine are you using? What is the compression ratio of the engine? How heavy did you build your aircraft? What Prop are you using? The list is endless.
WesRagle wrote:Mike53 wrote:I am waiting for Sonex's response to my question about max deck angle in a takeoff.In Canada at least we have to add 5 degrees to that number when performing the test.
Hi Mike,
Did you get a response from Sonex LLC? I'm betting that they couldn't provide an answer.
Wes
