daleandee wrote:
the Aerocarb don't tolerate a fuel pump very well, if at all,
they are quite sensitive to fuel flow bubbles,
the slide (at least on some of the older models) can stick or jam,
they pour fuel out whenever the mixture control is open,
they cannot be fed with ram air,
are they really worth the hassle?
Some argue they don't require carb heat. That's good but may not be totally true.
They are light weight. Yes but if you have to add 2 lbs of insulation and blast hoses you've lost that advantage.
They are reliably simple. This is true but so is a Marvel Schebler.
They are low cost. That really should not be a factor when considering your safety.
Absolutely no ill intent is meant.
SvingenB wrote:Running auto fuel without a fuel pump is generally not such a good idea in any case due to the vapor problem regardless of type of carb. The clue is of course to minimize losses by minimizing bends and fittings and/or have a way for vapor to escape.
