Fuel Cap Failure
Mon Aug 06, 2012 11:57 pm
by N111YX
The "older" Sonex tanks have this "Thermos-style" cap. Mine lasted about 300 hours of flight time before failure. Some rough math has me arrive at a figure of about 210 open/close cycles on the thing. You can see that the metal washer pulled through the rubber. After buying a replacement at $50, it seems that if one could aquire the rubber part only, it would be cheaper. I'll look into that next time...
Re: Fuel Cap Failure
Tue Aug 07, 2012 1:43 pm
by N111YX
I should add that the washer "contains" the rubber piece when it gives way so parts do not break free and go into the tank...
Tue Aug 07, 2012 8:00 pm
by GWMotley
Hi Kip,
I have heard this happening before with the cap on the other site. Hence, I have already purchased a spare to keep on hand. The other part I have been thinking about as well,is,the secondary trigger magnet as I have heard of the magnet falling out and possibly being stranded somewhere.
Tue Sep 09, 2014 12:12 pm
by sonex1284
My original fuel cap is about 1/2 way torn through. It still appears to be sealing. I found the direct replacement at Amazon for $20.58 with free shipping.
Shaw Plugs Snap-Tite 51019
http://www.amazon.com/Shaw-Plugs-Snap-T ... B0085PC8EI I'll update this post if it's the wrong size.
