pulley replacement
pulley replacement
Postby Mike53 » Fri Jul 06, 2012 5:21 pm
Hi all.
Has anyone replaced the supplied pulley /bronze bushing combo for a ball bearing type?If so what did you use?
Am I wrong to think that a ball bearing pulley will be better?To read Tony Bingelis on the subject one is led to believe that an anti-friction ball bearing pulley is superior to a bronze sleeved type and the larger the diameter the less friction created.If I read it right P126 The Sportplane Builder,the 1" pulley called for is inadequate.
Maybe I'm over thinking this.
Antoine de Saint-Exupery
Mike53
Re: pulley replacement
Postby onex28 » Fri Jul 06, 2012 10:11 pm
Mike on the photos I posted on the tri gear steering notice that I used an AN pulley aprox 1 3/4" dia due to the tension and 90 degree change of direction. On my rudder cables I used what Sonex plans call for as it is a pretty straight pull and they are used primarily as cable guides. I have no concerns about their longevity.
David
onex28
