rbarber wrote:I have ~1200 hours, on the original bolts for mine (Stainless) . No slop or issues. FWIW, my landings are not pretty, as I always practice short steep approaches.
GordonTurner wrote:Bummer. Glad you’re ok. Glad you’re at home. How many landings so far, and all pavement or some mix? Sounds like it was upper bolt?
How’s that Corvair treating you? I’ve watched your videos, thanks for sharing those.
Cheers, Gordon
Sonex1243 wrote:I installed cad plated steel as well per the SB. I have a little wiggle/slop on the lower end where the gear rod fits into the steel axle mount. Have you guys seen this and if so, what did you end up doing? I am thinking of bonding the two together with something to fill the cavity to stiffen it up but also enable removal if needed.
Rofomoto wrote:Just landed at home airport, as I turned off runway bolt broke and gear spins in mount. Easy fix with only wheel pant damage but going to change all gear bolts at each condition inspection.
