mccool wrote:It was my understanding that Cad plated bolts should not be used in the Titanium gear legs
Kai wrote:Joe,
We used ordinary Unbrako class 12.9 capscrews with mm thread. Our selection was based on our reaming out the holes in the engine mount and the gear legs to ø8mm (mind you, not cleared by Sonex tech, but we felt we had to do something). The thread length of the smaller dimension Unbrako´s is 28mm. For a 50mm shank, this would indicate a M8x1.25x80 capscrew bolt. According to the US Unbrako datalog, this carries part# 103070. You will have to check your engine mount for the exact shank length of the bolt.
Skippydiesel wrote:I am not the origional builder and may have my "wires" crossed but think I may have a Grove undercarriage - do these bolt concerns include Grove?
n502pd wrote:
Thanks much! come condition inspection time I will take a real close look at my original bolts for indications of movement. question, where did you get the reamer?
And another question.. did you also do the axel bolts to 5/16Th too? TKS!
Bryan Cotton wrote:I'm curious why some people have issues and some don't. Is it a bolt fit issue? For those with broken bolts, how easy are those bolts to put in? Same question for the guys with higher hours on one set of bolts.
I think I had to tap mine in with the light plastic hammer. Snug fit.
